no start
Old May 10, 2010 | 10:41 PM
art2239's Avatar
art2239
Default no start
need help; cranks but no start, fuel pressure good , no spark and no fuel to cylinders[plugs are dry] showing codes 41 &54 Its a 93 ruby with original opti
Old May 10, 2010 | 11:51 PM
jfb's Avatar
jfb
No spark, original Opti is in question. Use a noid light, or make one with an LED (light emitting diode) and a 680 ohm series resistor and connect across an unplugged injector plug. You should see light pulsing during cranking. The homemade light must be connected with the correct polarity. Another fuel test is to spray starting fluid into the MAF and see if the engine will start and run momentarily. Of course you must have spark to do this test. I don't know what your error codes mean, I own an 87.
Old May 11, 2010 | 10:54 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Check coil and ignition control module (ICM), too. Either or both can fail (cascade event) resulting in a crank, no-start condition like you're describing.
Old May 11, 2010 | 08:57 PM
art2239's Avatar
art2239
Thanks for the input ; starting fluid into the throttle body did nothing {no spark} also no pulse to the injectors, how do you test the ecm and coil? If you haven't guessed by now I do not have a FSM Thanks again
Old May 12, 2010 | 12:33 PM
jfb's Avatar
jfb
Best test for the ECM and the spark coil is by replacement.
Old May 12, 2010 | 12:51 PM
onedef92's Avatar
onedef92
You can swap out the coil and ICM from another LT1 engine, too, if you want to rule out buying new parts you might not need. Do you have a buddy with an LT1 by any chance? Vette, Firebird, or Camaro will do.
To no start
