No info from the ALDL port. Any help?
Old 05-11-2010, 11:55 PM
jak112460
jak112460's Avatar
Default No info from the ALDL port. Any help?
I'm helping a kid on his '85 Vette and at first it would not idle below 1000rpm. It would stall if the throttle was tapped. I rebuilt the throttle body and cleaned the IAC and it was in extended position when I pulled it out. We had a brand new IAC so I used that instead. Put everything back together and it would not idle below 1300rpm. I pulled out the new IAC and it looks like it is in the fully retracted position like it never moved. I wanted to see if the was any codes and when the diagnostic tool was plugged in to the ALDL port it read " no information available". Something to that affect. There is no information coming from the pcm to the ALDL port. I believe the car is in open loop and never coming out. How do I determine if the pcm is bad? Thanks for any info.
Old 05-12-2010, 02:27 AM
miscstudent
miscstudent's Avatar
Did you read this?:
http://forums.corvetteforum.com/c4-t...-data-fix.html
Old 05-12-2010, 05:00 PM
DarkBlue88
DarkBlue88's Avatar
Location: Charlotte NC, behind someone going 10 under the speed limit
Pin "E" adapter is required for TPI cars, hooks between the scanner connector and the ALDL, are you using this?
Old 05-12-2010, 05:09 PM
jak112460
jak112460's Avatar
I do not know if there was an adaptor as I was only helping on the mechanical part. The car owner took it to a friend who has a obd1 scanner. Is this adaptor usually included?
Old 05-13-2010, 11:48 AM
DarkBlue88
DarkBlue88's Avatar
I have an adapter for the Tech 1 scanner but a different cable end for the OTC 4000 scanner. The Tech 1 connector is labeled "pin E adapter" and the OTC cable end is grey instead of black. HopeThisHelps BriaN
To No info from the ALDL port. Any help?
Quick Reply: No info from the ALDL port. Any help?
