factory alarm
Old Mar 17, 2002 | 08:39 PM
Raidmagic's Avatar
Raidmagic
Default factory alarm
any help on shuting off the factory alarm? I have an aftermarket alarm with keyless entry and the factory alarm goes off when I don't manually unlock the doors. any help?
Old Mar 17, 2002 | 11:04 PM
Bluevette85's Avatar
Bluevette85
Default Re: factory alarm (Steve87VETTE)
Unplug the factory module. On my 85, it is located above the passenger kick panel in front of the ECM housing. Very tough to find.
Old Mar 18, 2002 | 12:58 AM
thmupr's Avatar
thmupr
I have an aftermarket alarm in my 92, and I tapped into the factory dis-arm wire coming from the door, and tied it to my aftermarket unlock pulse. This disarms the factory alarm at the same time, just as if you were using a key. I am not sure if the 87 is the same, but the factory wire on a 92 is a light green wire coming out of the door boot. When the door key is turned, it provides a ground source to disarm the factory alarm. Hope this helps, email me if ya want, I might be able to find out some more info for ya. :cheers:
To factory alarm
