Dewitt Aluminum Radiator, Installation
Old Jun 9, 2010 | 03:58 PM
LD85's Avatar
LD85
, I love my Dewitts rad!
Old Jun 9, 2010 | 04:05 PM
Pete K's Avatar
Pete K
I just installed mine a couple days ago. It practically installed itself in my 87. It was a shame to cover up such a nice piece with the ugly, plastic factory covers.
Old Jun 9, 2010 | 04:11 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
X 2
Exactly what I said when I received my first one. Looks extremely clean asking for it to be polished.
<---Benny Hill
Old Jun 9, 2010 | 08:13 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
Originally Posted by PLRX
Tom, just noticed this post.
I tried but the fan frame was totally against the radiator. I didn't want to damage the rad so I trimmed it. It was minimal work.
Great Product
There seems to be a lot of different opinions about using the spacers vs trimming the shroud, or both. We actually WANT the shroud to end up flush with the core face with as little gap as possible. Any gap is simply a leak, where the fan can pull through. It's kind of like a vacuum hose with a hole in it.
At first we supplied instructions to remove 1/4" of shroud material to make the shroud match the core face with little to no gap. Many people did not like modifying something or didn't have the skill to do it, so we changed to the spacer bars. The spacer bars move the fans back, the same 1/4" that interfered. So... it's one (trim) or the other (spacers) but not both or neither. Those who say nothing is required probably have the shroud crushing fin and bent the shroud. It might fit but that's not the way I'd do it.
Old Jun 9, 2010 | 10:30 PM
PLRX's Avatar
PLRX
2017 C4 of Year
When I bought the first rad for my 96 I install the spacers and the fan frame was smashing against the rad so I trimmed it.
The rad for 95 I did the same. If you look at the picture you can see that using the spacers and trimming the frame gives it a tight fit but, not smashing against it.
I careless about the trimming, that was easy. Fact is that your radiators are a great piece of equipment for Corvettes.
Old Jun 10, 2010 | 06:31 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
I couldn't care less about the trimming, that was easy. Fact is that your radiators are a great piece of equipment for Corvettes.
I appreciate that!
The only thing I can think of is that there must be slight differences in the housing/shrouds used from 90-96 because the one we have here worked perfect with the spacers. Your not alone is making this claim. I just wish we could get to the bottom of it so we can give accurate instructions. Maybe we need to double the spacer thickness, so no trimming is required?
Old Jun 10, 2010 | 07:21 PM
MK 82's Avatar
MK 82
The point Tom is trying to make it this IMHO.
1. Trimming is best solution
2. Plan B is using the spacers in lieu of trimming.
There should be no reason to trim and use the spacers.
I did the trim route and got a good tight fit without any undue pressure on the fragile fins.
Old Jun 12, 2010 | 12:45 AM
Calderone's Avatar
Calderone
LiterallyCool !!!
Thanks !!!
Looking forward to get one of this rads !!!
Old Jun 12, 2010 | 10:10 AM
enventr's Avatar
enventr
This is a great radiator-I have the stock thermostat and fan settings so the temps are about the same as the factory rad 195-202 cruising
Old Dec 18, 2011 | 04:13 PM
PONTIAC1977's Avatar
PONTIAC1977
Originally Posted by 94vettelover2
It nice to see people drive their vettes like their meant to be driven.I can't stand seeing a "older guy" drive a corvette slow.Whats the point?Buy a Mercury Grand Marquis if you drive slow.I remember one time this older guy was driving a new Zo6 slower than how my grandma drives.OPEN THAT THING UP once in awhile old manI'm not saying for those guys to speed but at least go with the flowing traffic
Hey sonny,want to run it?
Old Dec 18, 2011 | 07:06 PM
94vettelover2's Avatar
94vettelover2
I see you have a 94 as well.Sorry,you will have to wait till spring.Shes hibernating now
