need constant 12v...20amp?
Old May 14, 2010 | 12:17 PM
Mrmatt2009's Avatar
Mrmatt2009
Default need constant 12v...20amp?
Does anyone know where I cant get a 12v constant feed that can do max 20 amps and is around the dash / under steering wheel area? Thanks in advance!
Old May 14, 2010 | 12:56 PM
snoopdan's Avatar
snoopdan
make one? Just run a wire to the battery.
Old May 14, 2010 | 01:33 PM
Mrmatt2009's Avatar
Mrmatt2009
i would but then i would have to go through the firewall and more, i dont mind doing that im just checking to see if i have a better option first.... thanks for the help
Old May 14, 2010 | 01:47 PM
snoopdan's Avatar
snoopdan
Really it's better to not rely on the stock fuse block for anything like that. Just grab a fuse holder at Autozone and pop a 20 amp fuse in, put it in line with your device...and you're golden.
Old May 14, 2010 | 02:51 PM
jfb's Avatar
jfb
Use a blade type automotive fuse at 30 amps and an inline fuse holder. Make a power connection to the wire that goes to the input of the ignition switch. Do not use a crimp connection that pierces the wire as a power tap because it will not last long at 20 amps, cut the wire and THEN use a crimp connection to your inline fuse. Three wires crimped together.
To need constant 12v...20amp?
