Wanted to get some advice on how to disable VATS. I know one can use the resistor or aftermarket VATS elimination kits (Cha-ching), but I have been reading some posts that infer that the VATs can be disabled in the ECM. I thought VATs was a CCM function? Since I have Tuner-Pro and a Moate's Ostrich, does disabling the VATS thru the ECM really work?
Yes ,you are just telling the ECM not to look for the VATS fuel injector signal.
If you want all VATS functions gone ( no more key problems ) you still have to bypass the starter enable relay
On CCM equiped cars the resistor trick doesn't work because the resistor pellet is read by the CCM , not a VATS module as on earlier cars http://www.joestradingpost.com/vats/...ent_system.jpg http://www.joestradingpost.com/vats/...key_system.jpg
