1996 F45 Suspension Control Module Repair?
Old May 17, 2010 | 01:37 PM
bac22's Avatar
bac22
Default 1996 F45 Suspension Control Module Repair?
I think I have a problem with my 1996 suspension control module (pn 16205661), basically I'm seeing 2.2amps being sent to one of my shocks with the key off ...which means dead battery in the morning. As soon as I unplugged the connector going to that shock, my current draw went back to the normal 30 mA, so I'm guessing one of the high voltage transistors in the control module is shorted (FSM on the way this week so taking a WAG here).
The problem though is finding a new module...I'm having a heck of a time finding a used one or even a new one for that matter. Is there anyone who repairs these things?
Is it possible a bad shock would draw 2.2 amps even with key off? Logic is telling me that shouldn't happen with the key off.
Old May 18, 2010 | 03:14 PM
bac22's Avatar
bac22
Bummer no responses...think I might be in the SoL camp here...hopefully one will pop up on ebay at some point.
Old May 18, 2010 | 11:09 PM
The Green Rocket's Avatar
The Green Rocket
I think the '96 F45 stands all by itself and is unique for that one year. When you see parts come up here and on eBay you should grab some spares - shocks too.
Thomas
Old May 19, 2010 | 12:23 AM
96GS#007's Avatar
96GS#007
Thomas
Old May 19, 2010 | 06:34 AM
bac22's Avatar
bac22
Yeah...it is unique to that year and with only 2,896 C4's that got the option I suspect this is going to be a long hunt for used working ETBCM. My FSM's did finally arrive last night, so I'll be doing more troubleshooting this weekend.
Old May 19, 2010 | 09:58 AM
Leec4ce's Avatar
Leec4ce
ETBCM you can find very $$$. I think after you do some trouble shooting you will find ETBCM is not the problem.
Hopefully you will find a simple ground in your system because the availablity of replacement F45 parts stinks Try to find a replacement shock!
Please let us know what you find out with your trouble shooting.
Old May 24, 2010 | 10:41 AM
bac22's Avatar
bac22
Well now that I have the FSM, troubleshooting seems to lead me to the RTD module being bad. Wish I had a schematic of the RTD module since being an EE I could probably fix this easily, but with out that I'm going to try to back trace the circuits. I suspect that a high current voltage regulator has shorted causing current to be sent even with the key off. Of course as luck would have it, I'm not seeing any part numbers on the suspect component so sourcing it will probably be a bitch!
The irony of the whole thing is that each paragraph in the FSM says that the RTD Module is an extremely reliable component and generally not the cause of a problem...excluding my case I guess !
Old Jun 13, 2010 | 12:54 PM
bac22's Avatar
bac22
Okay final update, my problem has been solved. It was the RTD module that was bad. I was able to get another one from forum member weburke at a very fair price. No sure if he routinely sells parts here, but certainly someone I would have no problem dealing with again .
Old Jun 14, 2010 | 11:16 AM
Warren Seale's Avatar
Warren Seale
I'm curious to know if it was used or new. Are there any NOS left out there?
Warren
Old Jun 14, 2010 | 11:20 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Wasn't that the mule for the C5's F45 or Are they the same system?
Old Jun 14, 2010 | 11:26 AM
bac22's Avatar
bac22
This was a used system from another 96 vette that had 11,000 miles.
As an EE with background in digital circuits I opened up my bad RTD module and have to say it is well built; why it failed is odd. If I had a schematic of the RTD module I could have probably repaired it myself, but I was unable to match up the part codes on the component(s) I suspected had failed.
To 1996 F45 Suspension Control Module Repair?
