injectors
Old Mar 18, 2002 | 11:04 AM
Jim D's Avatar
Jim D
Default injectors
I had my injectors reconditioned by Ligrnfelter, installed them over the weekend . Fired it up had a miss ,unplugged the injectors one at a time found the #4 wasn't firing will call Ligenfelter today. Of course as usual I'm thinking maybe should have installed new ones, seems I do everthing twice. Are accel any good,don't want to use Ford ,because of having to have chip reprogrammed or install pressure regulator. Thanks for your help as usual Jim
Old Mar 18, 2002 | 05:17 PM
ASRoff's Avatar
ASRoff
Default Re: injectors (Jim D)
Jim I have found in the past that if you tap the Injector with a wrench they sometimes come right back, Try it and see if it works. If it doesent call Lingenfelter after all you did pay for the service. :cheers: :seeya
Old Mar 18, 2002 | 05:24 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Default Re: injectors (ASRoff)
I have the Ford SVO 24lbrs and they work great. My car even passed the strict MA dyno emissions test.
Old Mar 18, 2002 | 07:11 PM
1MoorTym's Avatar
1MoorTym
I've been using the Accel injectors for about a year now without any problems. Can't beat the price.
Old Mar 18, 2002 | 09:36 PM
89convt's Avatar
89convt
Default Re: injectors (1MoorTym)
I've had accel a year also and they are working fine. :cheers:
To injectors
