1993 issues
Well anyway it doesnt throw any codes but it is running rich as hell. Checked the fuel pressure and the local GM garage said it was "within spec" at idle and under load. The freaking this has 60 psi for heavens sake! When we took it to them they were to check it and they spent HOURS trying to adjust it. They were not even smart enough to use that little screw on the throttle body to jack up the idle from 700rpm to 900rpm. They are freaking dumb as hell and I cant wait to chew them out because they charge for a few hours to work on it and adjust it. Plan to get my pop back some money.
They couldnt even adjust the throttle cable, its slightly loose so we wanted to tighten it up.Is there any other issues that there may be that could cause it to run really rich other than the fuel pressure? After changing to another regulator that is between 30-40psi it runs almost like it should. Because of the GM garage though saying it was as best as it could be there is an issue. The 02 sensor needs cleaned up or replaced and 3 of the plugs are junk and we have to replace all of them.
What do you guys think? What else could it be? Think it could be the ECM? Just not sure what else to do at this point.
Oh, and what do you think the GM garage is going to say when I show them that the best tech guy they have is a freaking retard.
They said that the reason it would shift right in the upper rpms is because of the ASR button being on....lol The other thing was it was my dad and I who figured out the stock coil was junk. Idiots I tell you!
Down the road this thing runs like a champ. Even though its a D36 with the wussy gears.....lol
I dont think it has a proper tune.
Also, changing the tune would really help with the rich condition.
Another thing, if the larger cam needs more fuel (assuming so) woudlnt it be a safe assumption that it would run lean not rich, as it is now.
Thanks!
http://www.ttspowersystems.com/DataMaster.html
Thanks!
What do you mean by pulse width? So the larger cam would "trick" the ecm in to giving it more fuel than it needs?
Speed density systems use the MAP reading to calculate load based on manifold pressure. A typical stock engine produces 20 to 21" of vacuum at idle, as the throttle is opened manifold vacuum drops, (at WOT it is zero).
The stock fuel "program" in the ECM views 21" of manifold vacuum as "idle" and adjusts fuel flow accordingly, your engine with hotcam probably has around 16 or 17" of vacuum at idle so the ECM adjusts pulse width for a throttle that is farther open.
As others have mentioned you need a tune to correct the fuel program to match the mechanical changes caused by the hotcam.
carl_bruer@yahoo.com if interested, thx.
