injector size and fuel pump???
Old May 22, 2010 | 04:50 AM
patricksmithahhh's Avatar
patricksmithahhh
Default injector size and fuel pump???
do i need a new fuel pump for my turbo build on my 90 vette???stock bolt ons with a turbo at 5-7psi
i want to know if i need a bigger fuel pump and what size injectors i should go with
thanks
Old May 22, 2010 | 12:10 PM
jsiddall's Avatar
jsiddall
thanks
If you want to make more than about 350 HP or want to use E85 then yes. IIRC the stock injectors run at about 70% PW at WOT on a stock engine. Not much headroom there. Increasing the fuel pressure might buy you a bit but you are not going to go far.
I opted for a Walbro 255 l/hr intank. Should be good for way more flow than an L98 would ever need.
For injector sizing, ballpark math says take your new HP divide by stock HP and multiply your stock injector size by that number to come up with your new injector size.
Old May 22, 2010 | 01:43 PM
patricksmithahhh
so that would mean roughly 30# injectors shold be alright???
Old May 24, 2010 | 09:02 AM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
Run a matched set of 42's or 60's. Work great. Obviously U need a new .bin. Also consider the Moates.net "Ostrich" and my new MAF sensor.
BR - greg
PS: almost forgot - go with the GSS-340M by Racetronix
To injector size and fuel pump???
