Yes. Installed an MSD (7500 miles and no problems). The MSD has easy to follow instructions and has all the hadrware included to install. If you want a vented Opti, would highly recommend the MSD.
HHow do you know whether you need to replace the whole optispark or weather you can get away with just a cap and rotor kit. I have read that usually when the opti fails its rarely the optical pickup which would lead me to believe I could get away with doing a cap and rotor rebuild on it.
B bodies recieved vented optis in 94 so that opens up the donor parts pool a little
I was wondering that because my project LT-1 is a b-body motor and I was wondering if I could use the opti off of that because it looks like its brand new
So you already have all the pieces for a conversion...........IMO the second generation OPTI from GM is better than the aftermarket...I had more than 150K on a factory opti on my Impala.....and the car ran great...
