drm Rear coil over question
Old May 22, 2010 | 07:20 PM
92lt1vet's Avatar
92lt1vet
Default drm Rear coil over question
Hey guys just found a set of drm rear coilovers,but its just the rears is it worth it to just install them or do i need to buy a set of fronts also.any help appreciated
thanks mike
Old May 23, 2010 | 03:43 AM
jwt1603's Avatar
jwt1603
thanks mike
You can do either front or rear but you have to get the oppposite end leaf spring rate set up right to work properly with the coilover spring rate. And unless you're a chassis set up guru that's usually a challenge so people typically convert both ends to coilovers.
I'm converting to coilovers soon, complete kit from Van Steel should arrive next week.
