Backwards Alternator?
Old May 24, 2010 | 09:40 AM
armybyrd's Avatar
armybyrd
Default Backwards Alternator?
My '88s about due for a new alt-since my supercharger kit has the alt mounted backwards is there a particular brand that is better suited for this setup or is the direction have no effect on it?
Old May 24, 2010 | 02:43 PM
ShannonO's Avatar
ShannonO
Cruising
Buy whatever alt you want, just be sure to switch the alt fan over to the new alt.
Old May 24, 2010 | 06:39 PM
armybyrd's Avatar
armybyrd
By alt fan do you mean the blades direction?
Old May 24, 2010 | 07:06 PM
PAINTER MAN's Avatar
PAINTER MAN
I don't know what he means about switching the fan to the new alternator. Most alternators come with fans. With that said, I did have a problem with my fan. With the Powerdyne kit you may find the fan runs very close to the idler pulley. Mine did and the fan blades would flex and hit the idler. You could see the marks on the fan. I ordered a custom fan made out of billet alum that had no flex to it and fixed the problem.
Old May 24, 2010 | 09:38 PM
ShannonO's Avatar
ShannonO
Cruising
Yes, the new alt comes with a fan, but when you install the ProCharger kit, they provide a special fan that has the blades going the opposite direction. Make sure you re-use that fan.
Old May 24, 2010 | 09:45 PM
Vette Fast's Avatar
Vette Fast
Yes. The fan on your current alt. should have been replaced with a fan that came with the supercharger kit that while spinning in reverse will cool the alt. You will need to remove the fan from your current alt. and place it on to the new alt. In addition you may need to increase the size hole in the new alt for mounting if your kit is a procharger.
Old May 25, 2010 | 03:43 AM
armybyrd's Avatar
armybyrd
anyone know where a reverse fan can be bought?
Old May 25, 2010 | 08:02 AM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
Default Billet Reverse Flow Alt Fan
I sell billet fans that have the air flow reversed - much nicer than the ProCharger piece.
To Backwards Alternator?
