Tuner Pro RT won't save changes
it's always been a problem,TO SAVE
it save flags and constants ok, but the MAF tables don't save or save erroneous data, I tried reloading the software and tried updating it....
tried different bins....
comments plz need to tune car!!!!
If you're working with the MAF tables, are you trying to save a value that is greater than the respective table's scalar? This could also be your problem.
Well the version I have worked fine when I mothballed it for a few months, I isolated it for the moment to just the software itself, the autoprom ALDL connection is a little glitchy, but seem to be intermittent.
When the problem started I did "update" the software via "help" tab and it says that I have the latest, so I suppose since it was working at one time, ( the latest) i would not need to search for an older version.?
I have always had trouble saving and the truth be told JackDidley's solution was key in the past, however, it is shooting blanks today and days prior.
We'll, to comment on the value higher than the respective table scalar,I don't know what that means, most likely not; in desperation I plugged in minute changes, only to see the previous entry reappear immediately after ALL save buttons were clicked.
I even tried the download bin to file trick which frankly IIRC, works sometimes in the past
additionally, when I select all of MAF 1 values and boost the entire volume XX percentile, and when I reopen after a save; some entries would change and most recently all entries BECAME the same, this is spooky.
So it will not get past the change and save...
The smallest incremental change that you can make will be equal to the table scalar divided by 255.
For example MAF table #1, the scalar is typically 23. The smallest change you can make (and save) would be 23/255 = 0.09016.
For this example you can set 255 possible values with 0.09016 incremental changes within the 23 gm/sec range allowed by the scalar.
The editor may allow you to make a smaller change, but it wll have no effect when saved and reopened.
As the tables go up, the scalar also goes up which increases the size of the minimum incremental change. Table #6 has a scalar of 255 so the minimum incremental change is 255/255 or 1 gm/sec.
strangely, all the other tables and functions do accept changes...and hold even after shutting down the program and relaunching it.
Maybe you need to start all over aswell
yeah I was trying to avoid that, but you are right, I am uninstalling right now.....
Check the xdf item's conversion tab (right click, edit xfd item info, select the conversion tab. Are the correct table scalars linked? or is there a fixed conversion? Does the linked item have the correct address?
btw,uninstalled TP RT and re installed, the same files, ads, xdf, bin repopulated
