Blend Door Motor Position?
Old May 26, 2010 | 08:00 AM
My1st's Avatar
My1st
Default Blend Door Motor Position?
When the blend door motor is in the position shown should the door be open or closed? Thanks!
Old May 26, 2010 | 12:34 PM
SunCr's Avatar
SunCr
It doesn't matter - Programmer will cycle the door until it stops one way; reverse voltage and go the other. That's the calibration process which it undertakes after removing memory. If you don't get full travel, adjust the rod - in fact, yours looks like it could use a little more length, but it varies from car to car.
Old May 26, 2010 | 12:54 PM
My1st's Avatar
My1st
Thanks for the info SunCr!
To Blend Door Motor Position?
