Tech 1 scanner,how do I use it?
Old May 26, 2010 | 10:30 PM
Z51JEFF's Avatar
Z51JEFF
Default Tech 1 scanner,how do I use it?
One of the members was nice enough to let me borrow his Tech 1 scanner but cant figure out how to use it.The ABS system in my 91 isnt working and would like to pull the code so I know where the problem is.I hook the scanner up,put all the info on my car into the scanner and then the scanner asks for the ABS adapter,am I missing something here?
Old May 26, 2010 | 11:44 PM
Gear Jammer's Avatar
Gear Jammer
Active Streak: 90 Days
The way I understand it, is that the Tech-1 requires specific modules, depending on the vehicle youre troubleshooting.
Ive been looking (unsuccessfully) for a Tech-1 also, as practically every troubleshooting step in the factory service manual uses the Tech-1 output to determine the next troubleshooting step.
back to your original question, I think you need the Bosch ABS adapter. Try looking for Bosch ABS Adapter P/N TA00022. This is supposed to be compatible with 90-91 Y bodies (Vettes!)
I have this adapter for my 91, but I dont have a Tech-1
-john
Old May 27, 2010 | 03:57 AM
toptechx6's Avatar
toptechx6
As mentioned you will need the correct Bosch ABS diagnostic cartridge or a mass storage cartridge with the correct updates. Here is a link that may help, good luck.
http://www.corvetteactioncenter.com/...abs/index.html
To Tech 1 scanner,how do I use it?
