Z06 wheels on C4
Old May 26, 2010 | 11:07 PM
Dyno Jim's Avatar
Dyno Jim
Default Z06 wheels on C4
Thanks again for info on light problem, now that I'm able to
drive at night I have one other question. Will the Z06 wheels
I took off my 99 C5 fit on this 87 C4 or will I need spacers to
bolt up? I've been told that 88 and up would fit but 84 to 87
was different offset. Has anyone made this wheel change?
Dyno Jim
Old May 27, 2010 | 07:01 AM
The Bus's Avatar
The Bus
You will need a spacer to take up the difference in wheel offset. I believe your offset is 36mm and the ZO6 wheels are 56mm. A difference of 20mm or 0.79". I found some QUALITY wheel adapters on E bay from a place in CA. They were 1/2 the price as Summit or Jegs. Really top quality machine work on the adapters. If I remember correctly they were around $60 shipped.
I'm running after market ZO6 style wheels on my "91". Since my car had 50mm offset I didn't need to do anything. However my "01" Camaro had 36mm offset wheels so I used the adapter/spacers.
Old May 27, 2010 | 08:26 AM
jmrl98's Avatar
jmrl98
I have 1.25" adaptors on my 85 for 04 Z06 rims.
To Z06 wheels on C4
