96 Fuel Filter Replacement
Old May 27, 2010 | 08:40 PM
primalurges's Avatar
primalurges
Default 96 Fuel Filter Replacement
What is the procedure for releasing fuel pressure released prior to fuel filter replacement?
Also, I notice that my fuel filter has something blue around the pipe nut, is this likely lock-tight? If so, is that the proper method of sealing the connection?
Thanks for your help
Old May 27, 2010 | 09:31 PM
94z07fx3's Avatar
94z07fx3
A fuel pressure test gauge with discharge tube works well. So does starting the engine and pulling the fuel pump fuse.
I would bet it is RTV not blue lock-tite
No. The proper method is the use of viton orings.
Old May 28, 2010 | 06:20 AM
78pacer's Avatar
78pacer
As the OP said, pull the fuse and run the engine. It will start and die several times after that. Remove the fuel cap. Take a nail and a shop rag to the fuel schrader valve on top of the motor behind the fuel rail. Release the pressure from the schrader valve)like letting air out from a tire) and catch about a 1/8 cup of fuel into the rag and discard. That's it. I clamped off my fuel lines under the filler cover with vise-grips too. This way when I removed the lower return line, it wouldn't siphon what was left in my tank all over the garage floor.
Good luck,
Mike
Old May 28, 2010 | 12:46 PM
DonF's Avatar
DonF
Good luck,
Mike
That's it should be easy, hardest part is getting your hands in there.
To 96 Fuel Filter Replacement
