So what do I need to get goin?
![](/forums/images/ranks/2k-3k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
What do I need to program chips for my 86 ? Right now, I have a full version of TunerPro RT and an ALDL cable, and of course a laptop. Currently my 86 has a Hyperchip in it. Im planning on getting bigger injectors. My questions are
1. What burner equipment do I need?
2. Do I need any adapters for the ECM for chips?
3. Will I need a wideband O2 sensor installed?
help
help
![*****](https://www.corvetteforum.com/forums/images/smilies/willy_nilly.gif)
![](/forums/images/ranks/7k-10k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
You need a G2 chip adapter, some chips and a Burn2. Moates has all you need and you can download the software from his site. You also need the correct xdf file and a bin file to start with. Those are on Moates site too, I think.
Wide band helps but not required.
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
http://forums.corvetteforum.com/1574137209-post4.html
In your case you need the 6E files to suit your " 165 ECM
![](/forums/images/ranks/5k-6k.gif)
Steep learning curve but time to study.
http://www.thirdgen.org/techboard/di...ning-just.html
The computers (ECM ) are identified by the factory part #
ECM '165 refers to the #1227165 computer installed in '86 -'89 TPI cars ( Vette and F-bodies )
The ECM has a chip in it .
See
http://www.thirdgen.org/techboard/df...om-calpak.html
On the chip is the file ( the BIN ) that contains the information to run the engine.The BIN's are identified from the factory by a 4 letter code; ARAP mentioned is for a '89 Vette auto car.
Consider the $32 and $6E as the operating system ; just like you could have XP or Vista on your computer
Most ECM's will only operate with one particular system but the '165 ECM will work with both mentioned.The $6E is the later version with more features ( for tuning )
See
