Steering wheel MOVES!
Old May 28, 2010 | 11:48 PM
tjb101084's Avatar
tjb101084
Default Steering wheel MOVES!
i bought an 87 Vette and was told buy the seller he replaced the steering colum. Dont know why??? But when driving if I out wheight on the steerinf=g wheel it pulls down but then like its spring loaded goes back up when I let go???? Is the colum no good?
Old May 29, 2010 | 12:14 AM
don hall's Avatar
don hall
Default steering wheel
Does the wheel lock when you use the tilt wheel function?
Old May 29, 2010 | 12:16 AM
Azriel's Avatar
Azriel
Originally Posted by tjb101084
I bought an 87 Vette and was told by the seller he replaced the steering column. Don't know why. But when driving if I put weight on the steering wheel it pulls down but then goes back up like it's spring loaded? Is the column no good?
Fixed for readability.
Is it a Factory column, or something aftermarket?
Old May 29, 2010 | 12:41 AM
tjb101084's Avatar
tjb101084
And thats the differance between 4 beers and 9. LOL
Old May 29, 2010 | 12:42 AM
tjb101084's Avatar
tjb101084
The tilt works and its a factory colum.
Old May 29, 2010 | 10:10 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
the tilt lock mechanism has a problem
Old May 29, 2010 | 10:53 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
This is common on these cars because people use the wheel as leverage to get their big butts out.
Old Jun 1, 2010 | 10:25 AM
MyFirst90coupe's Avatar
MyFirst90coupe
I have the same problem. So far I have been afraid to mess with it.
Old Jun 1, 2010 | 11:31 AM
j-vette's Avatar
j-vette
St. Jude Donor '10
Old Jun 1, 2010 | 01:48 PM
wcvette's Avatar
wcvette
What would the repair require? I just purchased a 92 with this problem.
Old Jun 1, 2010 | 03:24 PM
ch@0s's Avatar
ch@0s
You might need a new circular navigational maneuvering device column.
Old Jun 1, 2010 | 05:15 PM
CaminoSS's Avatar
CaminoSS
You can pull the covers off and take a look at the tilt lock. As memory serves, there are 2 bars to lock it in. Alot of times one of the bars "slides" out and causes this problem. The other times the housing breaks and needs to be replaced. Easy fix if you have the tools and patience. Of course you can always take it to a shop to have it fixed.
Call some of the local body shops. They will have someone that repairs steering columns for theft/recoveries. Should run you about $150-200 based on what my guy tells me.
Old Jun 1, 2010 | 05:19 PM
Calderone's Avatar
Calderone
You need to tight some bolts from down under,im not sure but ive read about this on thirdgen.org,its the same problem
Old Jun 15, 2010 | 08:20 PM
klug932000's Avatar
klug932000
my whole steering wheel wobbles left/right/up/down, the telescoping lock work but it has alot of play in the wheel. i took off the cover the telescoping lock, the metal bracket going across and the large nut but i dont see what else to take apart to get in there
To Steering wheel MOVES!
