Cold Start Injector
Old May 29, 2010 | 08:09 PM
HdRider04's Avatar
HdRider04
Default Cold Start Injector
86 L98.... What are the symptoms of a bad cold start inj. I had a bad surging problem and got it fixed car ran great today. Went out to start it up (cold) and it does not want to hold an idle just dies unless I press on the pedal to keep the rpm's up until warm? Then runs great. (replaced the temp control sensor last week)
Old May 29, 2010 | 08:48 PM
rodj's Avatar
rodj
Originally Posted by HdRider04
it does not want to hold an idle just dies unless I press on the pedal to keep the rpm's up until warm? )
CSI only adds fuel while cranking ( cold engine ).Would have no effect on idle
Cleaned TB/IAC recently ?
Old May 29, 2010 | 09:17 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
In addition to the above, it could also be a bad MAF.
Old May 29, 2010 | 09:24 PM
HdRider04's Avatar
HdRider04
Rebuilt the TB and new IAC about a month ago.. on the scanner with the engine warm the IAC was @ 19
Re: MAF< Not throwing any codes at all...
I may have to check the TPS and reset mininum idle.
To Cold Start Injector
