Injector question..
Old May 30, 2010 | 12:22 AM
v8vette84's Avatar
v8vette84
Default Injector question..
I am putting together an LT1 for my 84' and i was wondering about injectors. I have been told stock #24's are going to be pretty much maxed out with my mods. I will be running a stock bottom end LT1 that uses the later Vented opti, it will utilize 12551561 heads (gasket matched intake), a mildly ported intake, cc503 cam, full roller rockers(aluminum), long tube headers into 3" catback, custom CAI, Stock opti with MSD cap+rotor. I have been told to run 30lb injectors, i found a set of yellowtop SVO injectors on ebay that were pretty cheap. I have heard a lot about the red top SVO's as well. I'm not sure of the difference though. What are a good pick for an injector? Also do i need to upgrade past a stock LT1 fuel pump? do i need an FPR as well? Thanks!
Old May 30, 2010 | 07:42 AM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
yellow top SVO's? What you saw were modified injectors. They work fine as long as they were done properly. The AFPR is not necessary as long as you have the right size injector. The LT1 stock FPR is a good unit.
Old May 30, 2010 | 11:38 AM
v8vette84's Avatar
v8vette84
These are one of the few "yellow top" sets i found..
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
What do you think about those?
Old May 30, 2010 | 12:17 PM
FICINJECTORS
Supporting Vendor
those are volvo injectors they are 310 cc at 3bar. So they are a little smaller than the red top which is 320cc at 39.15psi or 2.85 bar. They were never sold by Ford for their SVO. Which means special vehicle operations.. Now called ford racing.. They will work except the spray pattern is a little wide. for the price they might be worth it.
Old May 30, 2010 | 12:25 PM
v8vette84's Avatar
v8vette84
So these would be worth the extra money then?
http://cgi.ebay.com/ebaymotors/30-Fu...item5192537f6c
Old May 30, 2010 | 12:31 PM
FICINJECTORS
Supporting Vendor
they are used and probably can use a refurb because they have the 14.5mm ford o rings on them, which will cost you 89. We have brand new flow matched red tops for 279 shipped with the gm o rings.
Old May 30, 2010 | 12:35 PM
94z07fx3's Avatar
94z07fx3
IMHO You should just ask Jon for a set of 30# injectors if that is what you want.
I can't think of a vendor that has a higher reputation than FIC.
Old May 30, 2010 | 05:34 PM
v8vette84's Avatar
v8vette84
I would deff be all over that if i had the money. I don't have $279 to spend on injectors. Maybe $150, but i would like to spend around $100. Do you have any good used stuff? This engine has already taken my wallet and dumped it several times now. haha
Old May 30, 2010 | 07:56 PM
FICINJECTORS
Supporting Vendor
can you use 26 instead of 30? I have rebuilt sets of those i can sell you for 150
To Injector question..
