Motor Guru Please teach me
and this
indicate (to most anyway) humor. Since that didnt work out so well let me try this approach.. for 2500 bucks he aint gonna buy an intake and heads.. you think 300 chp is all it will make fine (hell 270 would be 30 more than he has now and its not the point, making torque is).. Which the TPI intake was meant to do..and the intake requirements of a 305 C.I. engine and those of a 350 C.I. at the same 5500 rpm are not that different that porting and port matching wouldnt help it come very close to being adequate for the intended application as stated by the OPand within his budget. within its limitations the TPI works very well.
Now a daily driver and part time autocross car would benefit more from bottom end grunt and mid range torque and throttle response than an extra 50 hp up at 5000 rpm.. so if your gonna be making power at 3500 rpm..why is that TPI so inadequate for this use at least in this stage of his game?
(BTW having no experience with "replacement TPI" doesn't mean I don't have any experience with TPI, )
As to exceeding the "published" CHP ratings of an LT4.. sounds like I may have committed some form of heresy there, beats me,
(that would be humor again) Shamdave good luck with your project.
I would like a driver that will light up the tires and cause some neck pain for my passenger,
I figure 300-400 horses to the ground would be good
I want to be able to drive it on vacation and melt the tires when i get there
It is an auto 85 with a tpi so here are my decisions
Carb or rebuild the TPI
What heads (new alumn re maned) or and machining do i do to the block?
Any one have any suggestions
Headers and exhaust?
will the trans and rear end be able to handle this? The trans was rebuild about 2 years ago.
But that's just me. Many good ways to spend $2500.
they also sell a 9.5:1 motor that makes 435 hp.. http://www.summitracing.com/parts/EDL-45901/ at $7000 dollars these are complete motors, and that isnt a stroker or anything exotic..
So, sorry to disagree with you but it aint magic and it doesnt take "several expensive mods" to do it.. I would bet that if shamdave bolted those same parts on his existing L98 assuming its in decent shape and he would see similar results.
HP cost money
and more HP Less dependable (not always but you see where im going here)
So here is what i am thinking
With an oil pressure problem (dropping DOWN to 2-5 PSI @ idle)
I am going to pull it and rebuild what i have
Some day this will go to my grandson on 12/10/2031 so it will need to last a while
Mild cam
Headers
Bored .30 -.35 over
have the heads ported and refreshed
Get injectors and clean up the plenium
Nix the AC and O2 Pump
Drive her till she pukes rebuild and start again!
HP cost money
Mild cam
Headers
Bored .30 -.35 over
HP cost money
Mild cam
Headers
Bored .30 -.35 over
I will convert over my TPI and get a hot Dist and away i go
the extras you will need are cam, gaskets, etc.
and a tune.
The tune would be around $200 and the gaskets about $100. Then there's hoses, etc.
Upgrade your intake and exhaust when you get another $1000-$1500 later. It will run just fine on the street with what you have.
" Oil pressure should be 20 to 80 psi (140 to 550 kPa). (In certain situations such as long, extended idles on hot days, it could read as low as 6 psi (40kPa) and still be considered normal.)"
Remember, the oil pressure gage is NOT linear. So with the pointer at a mid-way position does NOT mean the psi is half way between the lowest and highest marks on the gage. Shown on page 2-96.
Jake
My son, Ryan M. Cameron, graduated from West Point on 22 May 2010! He was commissioned as a 2nd Lieutenant and I pinned on his first pair of "Butter Bars" PROUDEST DAY OF MY LIFE!!
Jake
Who's tune are ya gonna bank on for $200?
Or do it now with ported heads!
Jake
(It does drop to 2-5 lbs after it is hot @ idle.)
Read his post above again....He says his oil pressure drops to 2-5 lbs hot idle..(Nothing about Lost 4-5 lbs after hot)..And he is talking about running pressure being 30-40 lbs, not his idle pressure... If he puts a mechanical gauge on the motor and only has 2-5 lbs oil pressure hot idle...That ain't good..Oil pressure this low at idle can possible mean theres significant wear or some other problems....WW
So what can i do to give her more go go and keep it dependable.
It has a performance chip and that about it not real sure where to go from there.
Please clarify thius: Does the oil pressure, when hot, drop TO 2-5 lbs OR does it only drop a total of 2-5 lbs? Big difference.
Jake
