New prob.. When the car is at idle temp low or 100 ish....when i drive the car temp climbs to hot ...shift to neutral and temp drops....ANY suggestions as to what to look for?????
First thing I would do is make sure there is no air in the system.
When you post it helps to know what year you have as there is slight differences as to the cooling systems and the best way to check them.
When the engine is moving the car it does work and makes heat, shifting to neutral, the engine makes little HP and makes little heat. Also what is ,"hot"? Normal C4 temperatures are around 190 F. You might also need to install a new thermostat, be sure to use the one that GM says belongs in it.
Sorry guys ,, it's a 1985E ,,,just rebuilt , almost certain the air is gone from the system.. but the sensor wire between 1 & 3 has no power ,,even when car it running ....temp on guage cimbs and falls with the gas???? i'm questioning the ground's? or the wires....any other suggestions would be great!! thanks
If temps follow immediately with engine speed I suspect an open to or at the sensor. First check for +5Vdc on the sensor wire; if present check resistance value of the sensor, it should read some finite value.
i suspect the 85E and 86L are wired the same. If they are:
On the 1986, the fan switch was between 1 & 3 and the dash temp gage was between about 4 & 6 (maybe 6 & 8, but it's the only one so you can't miss it).
I'd have to check the 85E FSM to see when voltage is present at the 1 & 3 switch. Maybe someone else can post that for you.
Jake
My son, Ryan M. Cameron, graduated from West Point on 22 May 2010! He was commissioned as a 2nd Lieutenant and I pinned on his first pair of "Butter Bars" PROUDEST DAY OF MY LIFE!!
From: One day you're a Comet...the next day you're dust... Arkansas
Are you saying the temp gauge rises and falls with engine RPM? It almost sounds like voltage induction from somewhere. Have you checked continuity and grounding on the sensor wire
