AC Clutch not engaging
Old Jun 1, 2010 | 11:30 AM
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
Default AC Clutch not engaging
My AC is not working. The blower will turn on high when i push the automatic button but I cannot hear the AC clutch engage nor do i feel a drag on the engine while driving. I've checked the fuse block and looked for loose connections. Where should I look next?
Old Jun 1, 2010 | 07:33 PM
cumbercr's Avatar
cumbercr
Check the freon. If the freon pressure is too low, the low pressure switch will not aqllow the compressor clutch to engage.
Old Jun 1, 2010 | 08:51 PM
89Corvette6spdFX3
I'll have that checked. I'm still running R12 and until now the AC has worked flawlessly. Isn't there a new refrigerant that is directly compatible with R12?
Old Jun 1, 2010 | 10:37 PM
walter schweigert's Avatar
walter schweigert
Yes, it is Freeze 12. R12 is still available online from Coolgas in Magnolia, Texas. You'll need your A/c certification to buy it though, which is relatively easy to get. Just an open book test and about $20 testing fee.
Old Jun 2, 2010 | 11:53 AM
SunCr's Avatar
SunCr
Nope and Freeze 12 is 80% R134. Mix 2 gases and you can blow it up. That doesn't usually happen because one or the other has leaked out and there's nothing left to mix. You should have your system pressure/leak tested. At this time of Year, a lot of shops will do it for free or for a few bucks because they want the big bucks to fix it. Do check on the hood, above the compressor, for compressor oil. Your Nippondenso compressor has an appetite for shaft seals and when it's shot, it sprays oil (and gas) on the hood. They can be repaired or you can plop down $500 to $800 for a new compressor - plus an Accumulator - and whatever gas you want to stick in it.
To AC Clutch not engaging
