Is it the Ignition?(L98)
Old Mar 19, 2002 | 07:09 PM
Vette9d1's Avatar
Vette9d1
Default Is it the Ignition?(L98)
A few days ago after reassembling the intake on my '91 I had it running (very rough with a high idle) and was adjusting the ignition when the car just flat out quit. Now when I try to start it, it seems like I am not getting any spark. The rotor is new and Im not sure if it could be a coil problem or the ECM? I already checked the fuse. How can you tell if the coil is bad?
Old Mar 19, 2002 | 08:26 PM
mash557's Avatar
mash557
Default Re: Is it the Ignition?(L98) (Vette9d1)
could you have knocked some wires loose at the distributor? Mine were old and the lock tabs are all broken so they can just fall out.
Old Mar 19, 2002 | 08:33 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: When you say you were adjusting the ignition...what were you doing and how were you doing it?
Coils rarely go bad, but having said that, I had one go bad just last week because it was not getting enough power.
There's a pickup coil in the distributor that can also seem to fail on short notice.
Perhaps someone with more knowledge will jump in here
Old Mar 19, 2002 | 09:44 PM
Raistlin's Avatar
Raistlin
Try hooking up an inductive timing light to check for sure if you have spark.
Old Mar 19, 2002 | 10:17 PM
pablocruise's Avatar
pablocruise
Default Re: Is it the Ignition?(L98) (jackdaroofer)
yeah!? :lol:
did ya happen to bump or dislodge or fracture a vac line? Did ya do the old turn-out-the-lights-and-look-for-a-blue-glow trick? (well ventilated dark garage please)? Engine won't turn over now or it runs rough?
Old Mar 19, 2002 | 10:37 PM
jfb's Avatar
jfb
Heres how you can test your spark coil. Remove the coil and place a .05 to .1 Mfd capacitor across the red and white primary wires and touch 12 volts across the primary wires. You can do this with clip leads from any source, like your car battery, battery charger, lantern battery (6v), voltage isn't critical. When you remove the voltage supply from the primary, there will be a high voltage spark from the high tension terminal on the side of the coil. Place a clip lead connected to either primary wire close (1/4 in) to the high tension terminal and observe the strength of the spark. It should be a healthy snap!
If the coil is good, then take your spark module out of the distributor and take it to a parts house that will test it for free. If ok, the only remaining component in the distributor is the pick up coil. The pickup coil should measure between 500 and 1500 ohms with an ohmeter.
Old Mar 19, 2002 | 11:20 PM
snaketr's Avatar
snaketr
Default Re: Is it the Ignition?(L98) (jfb)
okay here is a way to test to keep from getting shocked. Pull a plug and with the wire connected to it, touch the electrode to something metal and turn the engine over a verify one you have a spark and two what color is it. If you have a yellow spark then you have problems and if no spark well you have problems. If you are getting a blue spark you rignition is fine and you may have the timing way out. More than likely it is a module, these frequently go out, and if you have one from Napa, Autozone, or Advanced or any other auto parts store who carries them. This is your problem, even if it is brand new. I went through 3 new ones last time this happenend to me before I just ordered a GM. With the GM module in as soon as I hit the key it fired right up.
Coils don't go bad that often, and it is even more rare for the pickup in the distributor to go out. My bet is the module.
Old Mar 20, 2002 | 06:39 PM
Vette9d1's Avatar
Vette9d1
Default Re: Is it the Ignition?(L98) (snaketr)
Now I have replaced the coil and it still will not start. All wires are in there proper place (i checkeded several times) and I decided to take my module out. I took it to an auto store where they did some sort of a check and claimed it was working properly. So if I have a good coil and a new cap and rotor what could the problem be? Could the module be bad even though the test said it was good? Could it be the ECM?
Old Mar 20, 2002 | 09:52 PM
pablocruise
please forgive me, I'm not trying to be a :troll , but did you pull the spark plugs and check them for spark or any of the above mentioned tests?
I'd like to get into the basics too. You know, do we have spark, fuel, air, compression?? Did you change out the pick-up coil? Those two leads need to be phased(correct term?) properly,<---- I know about that one :eek: :D :lol:
dist not installed 180* out of sync? EST wire plugged back in along with the other dist connections? Do you have an Ohmmeter?
it's very rare for an ECM to go bad, but it DOES happen.
[Modified by 89 Paul in cal, 5:53 PM 3/20/2002]
Old Mar 21, 2002 | 07:07 PM
Vette9d1's Avatar
Vette9d1
Default Re: Is it the Ignition?(L98) (89 Paul in cal)
I have taken out a spark plug/wire and see a orange-yellow spark. It seems like it is close to starting but has never come alive. I am still wondering if I should go ahead and try a new module even though the auto store claims it is still good???
Old Mar 21, 2002 | 09:19 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Orange/yellow spark is a weak spark, but you put in a new coil.
Coil output is related to coil input, maybe someone can add something here..
But I am still curious that the engine was running, albeit badly, and then suddenly quit...never to start again!
Do you have fuel through the injectors?
To Is it the Ignition?(L98)
