tpis air pump eliminator
Old Jun 2, 2010 | 05:14 PM
gp85's Avatar
gp85
Default tpis air pump eliminator
I purchased a tpis air pump eliminator for my 85 auto.My problem is the arm hits the top of the alternator.I'm about a half a hole out.Has anybody else run into this?
Old Jun 2, 2010 | 05:26 PM
WW7's Avatar
WW7
I think your having this problem because on your year car the belt has to be changed to a 2" shorter belt..Just bolt the eliminator up solid and then change to a shorter belt.. WW
Old Jun 2, 2010 | 07:50 PM
gp85's Avatar
gp85
No it's not a belt issue.The arm going to the alternator hits the top of the alternator housing.As I said I'm about a half a hole out.Thanks in advance.
Old Jun 2, 2010 | 08:14 PM
gp85's Avatar
gp85
I found on a previous post that they had to grind down the alternator housing to get the arm to fit.My question now is, is it better to grind down the housing or the arm? Thanks
Old Jun 2, 2010 | 09:53 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Did you loosen the alt bolt and rotate it up/in?
Edit:
Actually, you probably put it together wrong. Notice how the alt support has to run in front of the alternator.
It will look like this...
Old Jun 2, 2010 | 09:59 PM
383vett's Avatar
383vett
Loosen the 15mm head bolt below the alternator at the pivot point on the bracket. This will allow the alternator to rotate toward the center of the motor and your bolt will line up.
Old Jun 2, 2010 | 10:02 PM
twin540's Avatar
twin540
Originally Posted by greggpenn
did you loosen the alt bolt and rotate it up/in?
Edit:
man that looks clean...
Old Jun 2, 2010 | 11:13 PM
GREGGPENN's Avatar
GREGGPENN
Thanks! Everything was cleaned, some parts bead blasted, painted, and baked for durability. Plus, I decided to reverse colors of the brackets and pulleys. I wanted the brackets to be less distracting.
This was after my test assembly.
(FWIW, I had to shorter all bolts a couple of threads and elongate one hole in the alt braket. That's because AFR's pattern was slightly off from an L98. Also, there accessory holes weren't quite as deep. Guess it shouldn't surprise me after I found their valve cover rim also didn't match stock. I've heard they don't call it making mods for nothing. But, I gotta wonder why these people can't copy some of the stock stuff better. (It's a d@mn good thing these heads are supposed to work well!)
Old Jun 3, 2010 | 08:47 AM
WW7's Avatar
WW7
Hey Gregg,
On my Dart Pro 1 heads, they are missing one of the holes on the head that holds the A/C bracket on...Now, you tell me why they couldn't put the same holes in there heads as the stock heads have so I could use all the bolts needed to hold the bracket.???? ..WW
PS::Also, to the original poster, you are still going to have to buy a shorter belt after your done..It says so in the instructions I got with my TPIS bracket..... WW
Old Jun 3, 2010 | 09:40 AM
gp85's Avatar
gp85
I think I need to start from the beginning.I've been collecting parts for years for an engine change and I'm just about finished the installation.From reading the posts over the years I built a 383 roller, 10.9 cr, comp .525 int and exh cam.Everything has been replaced with aftermarket. I was trying to figure out what to do about the bracket that goes from the alternator to the first and second header bolt and the arm going from the alternator to the third bolt.The only bolt I have in place is the lower alternator bolt and it is loose.From the picture above I have It installed correctly.Still the TPIS arm comes up hard against the alt housing so I can't get the bolt in.My 85 was built in Oct 84.Could it be they changed the design of the alternator after that?
Old Jun 3, 2010 | 10:57 AM
WW7's Avatar
WW7
Its possible that its a different alternator, I just went to the TPIS site and they say it fits the 85 up, nothing about fitting the 84..What you need to do is find out if the alternator you have is the same as all the other 85s and if maybe its been changed before you got the car.As far as the support bracket that goes to the back of the alternator, what I did was cut the bracket in half,then bolt one half to the alternator and the other end to the 3rd bolt on the headers. Next get a piece of bar stock or a long bolt with the head cut off that fits up inside the 2 halfs and weld it in or if you don't have a welder mark them and have them welded somewhere else You may have to bend the ends a little where they bolt up ..If you need pictures of mine let me know and I will shoot some and post them for you....WW
Old Jun 3, 2010 | 11:37 AM
gp85's Avatar
gp85
Thanks WW pictures would be great.I've owned my 85 since 1988 and bought it from the original owner. I'm pretty sure the alternator is the original because it only had 30,000 miles. Could anybody else with an 85 take a picture of their alternator.Thanks
Old Jun 3, 2010 | 12:32 PM
GREGGPENN's Avatar
GREGGPENN
Originally Posted by WW7
Hey Gregg,
What? Isn't your AFR build done? What are you asking me?
AFR put all the holes there. They drilled them a hair shallower plus the patter was off enough that I had to elongate one of the holes in the alt bracket.
Old Jun 3, 2010 | 05:31 PM
WW7's Avatar
WW7
I wasn't asking anything, I was just saying I have ( Dart pro 1 heads) that don't have one of the holes drilled for the A/C bracket..I was just commenting that they should make aftermarket heads with the same holes as the stock heads so everything would bolt up like the original heads...WW
Old Jun 3, 2010 | 05:49 PM
WW7's Avatar
WW7
George,
In these pics you can see where I cut the original bracket and put a piece of round bar stock inside both ends then welded the 2 ends to make a new bracket,you can't see the left side because the wires are blocking it. This is one of the easiest ways to fix the problem. With the Hooker headers they give you the little short tubes so you can use your original bolts so they stick out to the stock position.. You just have to use the third hole back instead of the second hole.This actually looks pretty good once you grind the weld smooth and paint them..Hope this helps...WW
Old Jun 4, 2010 | 06:31 AM
HlhnEast's Avatar
HlhnEast
May have been my post. I was thinking it may have been a replacement alternator (different housing) cause GM alts pretty much work on most V8 cars. I didnt want to grind the eliminator bracket but would have if necessary.
You could check at an auto parts supplier for a different cased alt or slot the elim bracket mounting holes. I always prepare to mod anything non OEM I try to install 'cause it just seems to be my luck.
I ended up using a 1" shorter belt too.
Good Luck!
Old Jun 4, 2010 | 02:29 PM
gp85's Avatar
gp85
Thanks for the help guys.
To tpis air pump eliminator
Old Jun 4, 2010 | 03:17 PM
GREGGPENN's Avatar
GREGGPENN
Only other thing I can think of is to tell you '89's take a CS130 (case) alternator. If you don't have that type, maybe that's the issue?
Old Jun 4, 2010 | 08:24 PM
HlhnEast's Avatar
HlhnEast
Hey Gregg, I noticed you dont have a belt on your engine in this pic. When I tried to put the bracket up front like that, the pullies didnt line up.
Old Jun 4, 2010 | 10:11 PM
GREGGPENN's Avatar
GREGGPENN
The A/C was still connected -- in the car. Kinda hard to run a belt like that! When I suggested the kit might have the bar reversed, it's because I did the same thing too.
Good catch with your post though. I had it reversed in the pic already posted. I found another pic on my computer where it's assembled correctly. I should look this this....
