need help!!
Old Jun 5, 2010 | 02:57 PM
AJ_1990's Avatar
AJ_1990
4th Gear
Default need help!!
i have an 85 corvette that i had bought a few years ago.when i bought it the motor was siezed. i rebuilt the motor and it ran great for about 8 months. then i had a fire due to a leaky fuel regulator. not much damage was done just burt my fire wall, engine harness, distributer and a few other minor things.but since then i got every thing repaired and got it running again but when i start it up it idles ok but whn i give it a lil gas it wants to die unless i floor it. i thought it could b some vacume leak but everything was fine do yall think it could b my mass air flow sensor??
Old Jun 5, 2010 | 03:36 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Un plug MAF and see if it runs better.
Old Jun 5, 2010 | 04:23 PM
AJ_1990's Avatar
AJ_1990
4th Gear
i did and it runs the same
Old Jun 5, 2010 | 09:15 PM
CorvetteMike2024
Corvette Enthusiast
Have you checked the fuel pressure at the shcrader valve? What about fuel filter? maybe plugged cats? Good luck....
Old Jun 5, 2010 | 09:38 PM
AJ_1990's Avatar
AJ_1990
4th Gear
yea thats another think i cant seem to regulate my fuel pressure i bought a new adjustable fuel regulator and diaphram and the pressure stays up around 70 and it wont adjust down...cant figure out y.
Old Jun 5, 2010 | 09:47 PM
Muffin's Avatar
Muffin
At 70psi that thing is running(?) pig rich. I would pull the regulator and check it out cause something isn't right.
Old Jun 5, 2010 | 10:16 PM
John A. Marker's Avatar
John A. Marker
The 85 pressure should be about 34-39 PSI at idle with vacuum line pulled from regulator and plugged. 70 is MUCH too high.
Old Jun 5, 2010 | 11:58 PM
AJ_1990's Avatar
AJ_1990
4th Gear
yea i know i took it apart before and everything seemed fine..when i turn the key on the presure reads around 40, its when the car is running that it shows 70psi
To need help!!
