Cluth Fixed!
Old Jun 6, 2010 | 04:57 PM
JAbraham03's Avatar
JAbraham03
Default Cluth Fixed!
Okay so I thought I would post this eventhough some may already know. I replaced the clutch flywheel and pressure plate on my 84 along with slave and master cylinder and once that was dont it did not work. After bleeding and bleeding of the clutch it still didnt work. Credit goes to my wife who found an article that talked about the bore size of the slave n relation to the clutch. I was not getting enough travel on the fork. Fix was to make a longer pin for the slave to push. This resulted in a solid clutch feel and also disengaged the clutch.
