HEI coil relacement
Old Jun 8, 2010 | 12:28 PM
snoopdan's Avatar
snoopdan
Default HEI coil relacement
Mine is working just fine, allthough it is the stock one. Is it even worth replacing? any gains with aftermarket ones like MSD or Accell? Or just a waste of $70 ?
Old Jun 8, 2010 | 12:48 PM
ch@0s's Avatar
ch@0s
IDK but if you need a spare you can have mine.
I went to this:
Old Jun 8, 2010 | 01:13 PM
snoopdan's Avatar
snoopdan
hmm, I guess I could switch to a 6AL, but don't know if it would be worth the effort or not.
Old Jun 8, 2010 | 03:20 PM
c4cruiser's Avatar
c4cruiser
The stock coil and distributor will work fine with a stock motor and even some minor mods. Go to a big cam, higher compression, headers, and an intake, you might want a coil with more output.
The 6AL won't really do anything to improve the stock system until you build some serious HP.
Old Jun 8, 2010 | 04:43 PM
bill mcdonald's Avatar
bill mcdonald
I had all the trick **** electrical on my 90 (high output coil, accel module, MSD 6AL). The msd failed and I had no idea what went wrong, I ended up going back to a stock set up since the coil was my last thing to eliminating everything and didn't notice a difference at all.
Old Jun 8, 2010 | 10:49 PM
l98tpi's Avatar
l98tpi
Max G’s
Stick with stock style HEI and just replace your coil, cap, rotor button, plugs and wires.
Old Jun 9, 2010 | 09:19 AM
snoopdan's Avatar
snoopdan
Well, I do have headers, breathless performance cold air, and run a 100 shot of nitrous at the track every weekend
Old Jun 9, 2010 | 09:32 AM
LD85's Avatar
LD85
I would replace it, on my 85, i would get intermittent misses and sometimes the car would just stall. They dont last forever
Old Jun 9, 2010 | 09:42 AM
Pete K's Avatar
Pete K
Coils degrade over time. If it is 10 years old or more, it can't hurt to replace it.
Old Jun 9, 2010 | 01:23 PM
bill mcdonald
Nitrous.
Now I would probably at the very least use the MSD with N2O. A new coil too of course
To HEI coil relacement
