ALDL scanning issue
Old Jun 8, 2010 | 07:26 PM
Scott85's Avatar
Scott85
Default ALDL scanning issue
Vette is a 93 . I have an Actron CP9145 scanner that I've been trying to scan my vette with . When I plug the scanner in and try to read the codes, it keeps telling me it isn't plugged in. BUT, when I go into the field test mode on the scanner, the fans will kick on, so I know it has a connection through the ALDL port . It doesn't look like the ALDL port has been tampered with. I've read it might be tied into the cigarette lighter fuse , and that works. The scanner also works on the other cars I've had , both OBD1 & 2 . Anything else I can try ?
Old Jun 8, 2010 | 07:57 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
What year is your car. Some early C4s require an adapter with some scanners.
