Missing when Warm ?
Old Jun 8, 2010 | 09:53 PM
1990 Rudy's Avatar
1990 Rudy
Default Missing when Warm ?
Ok 1990 VERT, 80K maunal.
Runs great when cold. It warms up and runs terrible. I make it home but not with a lot of power. I have replaced 6 of the plugs the ones on the passenger rear area going to be replaced tomarrow.
I have also done the Fuel Filter. ?
I will be doing Wires (Taylor) and AC DELCO cap and rotor this week also.
when I have had vehicles with bad wires or plugs it was constant not when it gets warm .. any ideas ?
It reminds me of a VACCUM leak in my old 289 ?
Thanks,
Steve
Old Jun 8, 2010 | 10:28 PM
Harsh20's Avatar
Harsh20
since you say it happens after it gets warm and not throwing codes (i assume)
cat converter comes to mind, then O2 sensor (but that should throw a code), then injectors not flowing properly when warm. check those areas during your plug change then look for naked wiring around the coolant temp sensors.
Old Jun 8, 2010 | 10:38 PM
1990 Rudy's Avatar
1990 Rudy
yea it is a hard mis...
What would a bad cat feel like?
at idle you can feel it --------drop---------drop-------drop
And worse under a load ?
Old Jun 9, 2010 | 12:27 AM
blkvette94's Avatar
blkvette94
Navigator
yep the cats usually keep you from a certain higher RPM.
COuld be MAp or 02 Sensor. time it-- if it happens at 5 minutes from cold, about 3 from warm and about 2 from hot start it is moving into computer mode and trying to adjust fuel based off the 02 sensors. They may not throw a code if they are really dirty and dying.
on the Map spray a fine mist of lightly soapy water on it and see if you see it streak into the sensor-- could be broken.
Check EGR, PCV.
If it happens when it is ambient hot-- not eng hot-- check output from fuel pump.. sounds crazy but in texas heat I had one that was failing and would lower output on a 90+ day...
if it is running rich check your temp sensor
Old Jun 9, 2010 | 01:06 AM
jfb's Avatar
jfb
Another possibility is the spark module. A common problem with spark modules is with age, their spark output gets weak when they get hot. Check the spark cold and hot.
Old Jun 9, 2010 | 07:22 AM
1990 Rudy's Avatar
1990 Rudy
ok, Should I buy a Chiltons manual ? or go get a Field Service manual.. I know the HAYES are useless!!!
Field Service manual.. where do I get ?
Old Jun 9, 2010 | 09:52 AM
BerniesVette's Avatar
BerniesVette
I just went thru this on my '95 S10. I had two plug wires that were burnt. When cold they would work but when they got hot they would not. My S10 runs like a top now that I have replaced the plugs, wires, dist cap and rotor button. Of course, there are other things that could cause your problem too. But the idea is to start from a clean sheet with parts that you know are working properly before you try to diagnose it further. Good luck with your repair!
Bernie
Old Jun 9, 2010 | 12:02 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
I'd bet injectors. Check them with an ohm meter if one is handy.
Old Jun 9, 2010 | 12:39 PM
esham's Avatar
esham
Check them both cold and hot.
To Missing when Warm ?
