tcc switch
Old Jun 8, 2010 | 11:45 PM
fatblock's Avatar
fatblock
7th Gear
Default tcc switch
i am a newbie anybody wired a manual torque converter lock up switch into a 1988 c4 looking for easy wiring diagram
Old Jun 8, 2010 | 11:59 PM
rodj's Avatar
rodj
You want to manually turn it on or lock out the automatic operation?
Old Jun 9, 2010 | 01:49 PM
355tpipickup's Avatar
355tpipickup
I rewired mine so it locks up when its shifted into 4th
Old Jun 9, 2010 | 02:28 PM
383vett's Avatar
383vett
My 84 is wired so a switch on the console can lock or unlock the torque converter on command. I am using an aftermarket transmission controller for my 4l60e. I used to run a 700r4 and did the same thing. You'll need to find the wire out of the ecm that controls the lockup solenoid in the transmission and ground the thing through the switch. That will give you lockup. During a run, I will lock up my converter right after the 1-2 shift. Just have to remember to unlock it before stopping.
Old Jun 9, 2010 | 05:47 PM
355tpipickup
why would you lock it during the race... I thought it robs power to lock the converter
Old Jun 9, 2010 | 07:42 PM
rodj's Avatar
rodj
Takes out the convertor slippage so all the power is going to the wheels
A non locking convertor always has the engine doing more revs than what is coming out of the trans
Old Jun 9, 2010 | 07:49 PM
rodj's Avatar
rodj
That way you will still have TCC unlock when you hit the brake
Tan/ blk wire from trans to computer
Old Jun 9, 2010 | 08:29 PM
383vett's Avatar
383vett
Right Rodj. Once my car is launched, I don't need the converter to slip anymore. When the converter is locked, it becomes similar to a clutched transmission where the motor is connected directly to the driveline. With the converter locked up, my car goes throught the lights at 6500 @ 126 with 4.33 gears which is perfect for my setup. Without the converter locking, I'm at 6700 @ 120 through the lights and the car is no longer pulling. My car is .3 seconds quicker with the converter locked. When the converter locks, a solenoid opens in the tranny and fluid dumps out of the converter allowing the clutch disks (I have 3) to contact and grab. It doesn't take any horses to lock the converter.
Old Jun 9, 2010 | 11:19 PM
fatblock's Avatar
fatblock
7th Gear
i want to manually lock it. 383 did cut the wire from the ecm or just splice into it to run to your switch
Old Jun 9, 2010 | 11:55 PM
slickfx3's Avatar
slickfx3
someone can program your chip to make the TCC behave anyway you like it.
Old Jun 10, 2010 | 01:26 AM
355tpipickup
Its been to long since i have messed with my wiring, but i would also like to try this switched deal. Sounds like i might pick up some speed in the 1/4! Like i said i did somethin were it locks up only when i shift to 4th. I will have to lok back through my threads is guess. I got the idea from peteK on this forum i think it was.
Old Jun 10, 2010 | 10:25 AM
383vett's Avatar
383vett
Actually, since I'm now running an Accel DFI with a TCI transmission controller, I just intercepted the wires going into the tranny's lock up solenoid and gave one terminal 12 volts and the other ground through the switch. I wanted to make sure I had a full 12 volts to activate the solenoid. To those wanting to lock up during full throttle, make sure your converter is up to it. I have a 3 disk Vigilante converter from Precision Industries that works. Most other converters have a single lockup facing that may not last long.
To tcc switch
