Engine cleaning an LT1
Your best bet is to probably just carefully wipe down anything you can reach and take off, or move, parts that are easy to do to gain access to other areas. Water+Opti=
Your opti (if it is the original) is also non vented. Meaning if moisture gets in there via condensation , water hose , power washer..... it has no easy way to get out.
This is what I've done to all my Vettes to include my 92 wich had no ventilation on the opti.
I've done the car wash pressure, the garden hose and now my personal pressure washer. I hose down the engine every time I wash the Vette but, immediately after I blow all the water away with the leaf blower. Do not hose the opti, the coil, fuel injectors directly.
Some people is going to jump on me for this but, here I go
This pictures were taken the day I bought my LT4 Vette
This is how the engine compartment looked
I took the Vette from the old lady's house to the local car wash and I was ruthless with the sprayer. Knowing
it was a project car I hammered the opti, coil, everything you are not supposed to do.
The engine fired up no problems, no misfires NOTHING bad about and drove home.
This is the best the LT4 looked before I opened the tool box.
LT4 Vette last Sunday
Not quite...This is the bottom of a '92 opti. The three holes vent the inside of the unit to atmosphere.
Are those three holes enough of a vent? Nope. Many problems with the early optis. The later LTXs used a closed system that worked like a PCV. It drew air through the unit to suck moisture out.
I think you could wash the '92 engine and be OK if you could avoid getting condensation inside the opti. I had a problem with condensation inside the distributor when I rinsed my '65 engine with cold water. The inside of the distributor was soaking wet from condenation. I would use warm water to rinse the engine if I absolutely had to wash it. But...am I going to wash my '92 engine? Nope.
It cleans the oil and grime right off and leaves no moisture to deal with. Its not easy on plastic parts, so be fore-warned.
Ive also used a pressure washer, on both of my '94s and on my LT4, no problems, yet I didn't spray the Opti or that area directly.
