Hi, having problems with my 93 LT1 6sp. I have a no start condition, engine cranks but no injector pulse. 12v to the injector but no pulsed ground.
The CCM shows a C41 (no communication) and I have checked the wires for any opens or shorts and continuity. Everything checks good, no shorts or opens and .5 ohms between the CCM and the ECM. I see in the schematic there is a splice (S222) in the circut. Can anyone tell me where the splice is, I think I may have corrosion causing an interuption in the communication. Thanks in advance for any help.
According to the factory service manual splice S222 is located in the instrument panel behind the cruise control module. Note for future reference that location of all components, connectors and splices is listed at the end of each electrical section, hope that helps, good luck.
