Hi:
Just wondering if someone can point me in the right direction.
When i sart the car cold, It surges.... 400-900 RPM
No codes, new fuel pump, TPS set right. IAC set right.
It doesent seem to do this when its warm? Could it be a VAC line somewhere..... where do you suggest i should start to look.:o
my 86 does this as well,but only the first start of the day..I replaced all vacuum lines I could see but didn't help..so far it hasn't affected anything that I can tell,it goes away as soon as I put it in gear and start driving..sorry I couldn't be more help but I'll follow the post and see if you find a solution. Good Luck
