new 86 vette owner:please help
Old Jun 10, 2010 | 02:16 AM
JD868's Avatar
JD868
Default new 86 vette owner:please help
hey folks,just want to say in advance thanks for all the help...I'm the proud owner of an 86 for about 5 months now but can't figure out what I think is a transmission problem..auto 700r4 all stock car..trans shop says its an engine problem,mechanic shop says its trans problem..ok,at about 35mph is when it starts jumping back and forth,best way to explain it is imagine a manual trans in 5th gear running 20mph with clutch not pushed in and trying to coast,but when you give it gas and put it under a load it does fine..this is what my car seems to do..I replaced tcc solenoid,had valve body checked,and apparently had a 1-2 shift accumulator broke(?)anyways,both shops checked it off as good,yet still the problem remains...anyone heard of this,any ideas? thanks again
Old Jun 10, 2010 | 07:51 AM
Pete K's Avatar
Pete K
The only thing the computer contributes to the 700r4 is a lock up signal. It is usualy a speed of about 35 mph that is programmed into the prom. What you are experiencing is normal, and annoying.
However, that is the way GM built them back in the day.
Your options are:
1) Live with it
2) Reprogram the prom to raise the mph (lock up apply) higher.
3) Rewire the lock up (in the pan) to work for 4th gear only.
Hurst makes a plug and play ( or at least they used to) adapter does the 4th gear only thing without cutting and splicing.
Old Jun 10, 2010 | 08:43 AM
Churchkey's Avatar
Churchkey
Its aggravating, What I did with mine was to run the car in "D" around town, shift up after 45-50 mph.
Old Jun 10, 2010 | 09:50 AM
ThomasRetUSN's Avatar
ThomasRetUSN
I had the same problem with my 86 and I replaced the the chip with a Hypertech power chip from Eckler's. Street Runner part # A9015 (cast iron heads) $234.99. Now it shifts like it should and very smooth.
Old Jun 10, 2010 | 01:12 PM
JD868's Avatar
JD868
thanks everybody,I'm relieved at least that it's not something serious but it is like you say very annoying..Thomas,does the chip you bought only work at full throttle or is this another one,I've had trouble trying to figure out what chip to buy if any..oh,I have a late 86 aluminum heads if that makes much difference..thanks again for the help
Old Jun 10, 2010 | 01:20 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
What I didn't hear is what gear are you in?
Can you feel/hear/see all four gears?
Can you detect when the TC locks up?
What gear is the trans in when the bucking happens?
The trans should shift into 4th and the TC lock at around 43-45MPH under steady throttle.
It sounds like the TC is locked, but you need to confirm the up shifting is normal and the TC locks.
Old Jun 10, 2010 | 01:43 PM
JD868's Avatar
JD868
JrRifleCoach,it does seem to shift through the gears fast,but I was told that was normal(?)..the bucking starts in 4th gear around 35mph and lockup seems to start around 40-43mph..I can drop it down in D and it is not near as bad but still detectable
Old Jul 20, 2010 | 11:29 PM
JD868's Avatar
JD868
so I'm back to this annoying situation..now this bucking seems to be happening at faster speeds,say up to 50-55..it almost feels as though it only does it when you are barely on the gas,so I'm wondering is it possible that my tps may have a dead spot and getting worse?
this may not be something that could even be possible but I thought I'd ask...thanks
Old Jul 20, 2010 | 11:43 PM
Marv02's Avatar
Marv02
Default Rewire
How do you rewire the lock up so it only works in 4th gear.
Your options are:
1) Live with it
Old Jul 21, 2010 | 07:30 AM
PAINTER MAN's Avatar
PAINTER MAN
PM sent
Old Jul 21, 2010 | 10:39 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
This seems to be spark plug wires maybe. I would change them to a good set, and make sure the plug end of the wire is pushed onto the plug securely.
Old Jul 21, 2010 | 11:39 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
It could be a misfire. If the car hasn't had a tune up in a while, give that a try. Replace the cap, rotor, plugs, wires, air and fuel filters.
Old Jul 21, 2010 | 04:43 PM
JD868's Avatar
JD868
thats what I thought the first time around,and still is a possibility..but I have put new autolite wires on(junk)then put beldon wires on,new cap,rotor,plugs,air filter,fuel filter,thermostat,trans work including tcc solenoid and valve body cleaning,battery,etc...
I guess I should add that I put the fuel filter on last night along with an oil change,and after while sitting in a drive thru with a car behind me I noticed it's headlights illuminating quite a bit of smoke coming from my car..this made me nervous so I pulled off and checked it out..it seemed to be white smoke but smelled more like gas than oil,this is the first time it has done that except for the usual puff of smoke on start up..not sure if this has anything to do with the jerkyness(new word)
back to the point,I wonder if the tps could be bad or could that cause this symptom...also could bad ujoints cause enough movement to make a car buck when not under a load..
these are just some thoughts so any comments on these or new thoughts would be helpful for process of elimination
To new 86 vette owner:please help
