1993 Opti purchase option
Old Jun 13, 2010 | 05:30 PM
choopes's Avatar
choopes
Default 1993 Opti purchase option
Some of the options I'm looking at ar MSD, dynaspark, Deltec, and stock GM. Searching the post I see negative things about MSD, and dynaspark, but they are all older post. How are they now? If you had to buy one this week, what would be your choice of ditributor, and why?
Thanks!
Old Jun 13, 2010 | 06:59 PM
surfer93's Avatar
surfer93
I would get a delco opti or accel, I have had good luck with both. I am going to buy a MSD cap and rotor, so I can vent the opti.
I would not buy a MSD, just do a search and you will see why.
Make sure and glue a hose to the weep hole on the opti and you will never lose a opti to coolant.
Old Jun 13, 2010 | 07:35 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Vent a stock GM opti replacement.
Be very careful putting the replacement on!
Old Jun 14, 2010 | 10:45 AM
BillysGreen93's Avatar
BillysGreen93
I just put in a MSD opti in my 93 this month. So far the engine is running great with it. The venting kit is included and was real easy to install.
Old Jun 14, 2010 | 01:11 PM
FOXX's Avatar
FOXX
What about the Delteq Opti-Direct system? I'm seriously considering getting this. http://www.delteq.com/
Old Jul 19, 2010 | 11:56 AM
choopes's Avatar
choopes
It seems like Delteq has had some problems. May be going out of bussiness, or at least unstable. Has anyone made contact with those folks recently? If they go away, so will any support.
Old Jul 19, 2010 | 02:51 PM
airplane50's Avatar
airplane50
Put in an MSD Opti in my '94 a little over a year ago, (6,000 miles), along with a new water pump. No problems. The one I replaced was a GM opti installed at the Chevy dealer which lasted 7,000 miles. The new water pump which was installed with the GM opti leaked at the shaft wiping out the opti. The MSD looks to be excellent quality. Heard that the original MSD opti's had problems that they seem to have resolved.
Old Jul 19, 2010 | 05:21 PM
timmy 93's Avatar
timmy 93
I can say MSD support is very good.I have a 93 lt1 had a code 36 sent it back to MSD Within the year 12 months of purchase. No questions they went through the Dist. and repaired it. I believe the new Msd have all the bugs worked out. Which ever one you buy check the support. At around $500. or so vary important in my opinion.
To 1993 Opti purchase option
