Need help with a pipe to replace cat on 87-90
Old Mar 20, 2002 | 11:07 PM
vettemech85's Avatar
vettemech85
Default Need help with a pipe to replace cat on 87-90
I have a TPIS front Y pipe that I need to connect to a Borla 87up rear Y pipe. The TPIS pipe is 3 inches est. The Borla is 2.5-3 inches, but it is "flanged" like a brake line. I was originaly planning on doing a modified 87up cat like TPIS suggests, but a straight pipe makes more sense. Should I cut the Borla rear pipe so it will be straight, and get a longer pipe? Or try to work with "flange" and stock cat bolt piece (on outside of pipe has 2 bolt holes) that came attached to the rear pipe? If anyone has the TPIS Borla combo, please let me know what worked best for you. BTW I have minimal tools. No welding equipment just basic hand tools saws etc. Thanks in advance.
