Engine Light :(
Old Mar 21, 2002 | 12:11 AM
Jasin9687's Avatar
Jasin9687
Default Engine code help
Hey, its me agian. I have a 96 LT4 and the check engine light came on, well i got the code.. P0300 which is a multiple engine misfire, Im not sure where the hell to start looking for the problem or what I should do... I have a Intake, exhaust, and throttle body, WHAT SHOULD I DO?? :mad :mad
[Modified by Jasin9687, 4:50 PM 3/22/2002]
Old Mar 21, 2002 | 12:43 AM
No Go's Avatar
No Go
Default Re: Engine Light :( (Jasin9687)
Heh join the club...I have a light as well.
I would check to be sure everything is hooked up and in top condition-fresh plugs, all wires connected, etc.
Might even be some bad gas-I'm not sure.
I haven't had mine read yet so...but I just started it for the first time after doing a cam swap...:)
Old Mar 21, 2002 | 02:03 PM
ConeKLR's Avatar
ConeKLR
Cruise-In II Veteran
Default Re: Engine Light :( (No Go)
Could it be a bad O2 sensor?
Old Mar 21, 2002 | 02:37 PM
Crushinator's Avatar
Crushinator
Default Re: Engine Light :( (ConeKLR)
That's a definite possibility Jasin. When I put the Power Effects on, I think I remember seeing the drivers side O2 sensor looked slightly melted. You might want to check that. Very easy to swap out and fairly inexpensive. I'm rackin my brain tryin to figure this out for ya.
Old Mar 22, 2002 | 12:49 PM
Jasin9687's Avatar
Jasin9687
would the o2 sensor make the P0300 code though?
Old Mar 22, 2002 | 03:13 PM
Crushinator
Did you check all the vacume tubes and throttle body gasket yet? I think if it were the o2 sensor the car wouldn't run right, but you never know.
Old Mar 22, 2002 | 04:00 PM
BAdAzZV8's Avatar
BAdAzZV8
Default Re: Engine Light :( (QuickSilver97)
Having a bad O2 will screw your idle, and your gas mileage. That is what it did to me.
To Engine Light :(
