Repairing Plastic Trim
I'm in the middle of a carpet install and just about every piece of plastic trim is broken and cracked. Wherever possible I order new pieces, but I haven't been able to find the pieces in the hatch area that hold the sides of the carpet down just below the window. These are the same pieces that the curtain clips screw into. If any of you have a source for these, please post it because I couldn't find it. Because these pieces are hidden for the most part by other trim I wasn't too overly concerned with aesthetics. I just wanted it to hold the carpet down.
Anyway, here's what I started with. The driver's side was in three pieces with big chunks missing. The passenger side had a huge crack and the end was missing.
I started out by sanding everything and then tacking the pieces together using a wood burning iron. I also have a real plastic welding iron and a hot air welder, but the wood burning iron works better for me for small fragile areas. It's important to fill with the same type of plastic that's being repaired otherwise they won't stick. I am also replacing my dash trim and used the old dash for donor plastic. Here's the first "weld":
I melt a V groove into the joint and then melt some donor plastic into the groove. I then flip it over and do the other side. To fill in the missing pieces I cut some donor plastic to an approximate shape:
Then I weld it, flip it over and repeat until I have it close to the original:
I did the same to the end and re-drilled the holes. If this were to be seen I'd do a lot more sanding filling and painting to make it look presentable. Here's the end product, on the bench and installed:
Ron
Welded before fill:
In primer:
Finished Bezel:
Ron
