Reflashable chips for a 1990?
What is the absolute cheapest way to get started with reading/writing my own EPROMs? I don't know anything about it yet, just what I have read in the stickies and what I have read browsing the forums and searching on google. Is there some kind of upgrade for the 1990 ECU that would use a flashable EPROM instead of one that requires erasing? How about some kind of interface board that would allow me to make changes on the fly?
http://forums.corvetteforum.com/1574137209-post4.html
http://forums.corvetteforum.com/1574141722-post6.html
If you want to go the cheaper chip reprogramming route you can use a 27SF512 chip in the same memcal adapter as mentioned in link above with this unit to program them
http://www.moates.net/product_info.p...roducts_id=197
If you believe you only need some minor changes and that will be it then get the burner.(cheaper )
If you know you are going to be playing around with the tune / doing future mods that will require extra tuning get the emulator (Ostrich )
As noted ;
as simple as hooking up the laptop, making changes and driving off.
The burner requires you to open up ECM , remove chip / erase / reprogram / reinstall /test ;
didn't get it right / take it out and do it all again over and over until you are happy
Not as good as the Ostrich, but not bad.
