-88 not going into closed loop
Old Jun 16, 2010 | 11:54 AM
jutammel's Avatar
jutammel
Default -88 not going into closed loop
Having somewhat high idle issue. Car starts up around 1300rpm and never goes below 1000rpm. I have done base idle adjustment to 450rpm as repair manual says, but still high idle.
I hooked up AutoXray and noticed that car never goes into closed loop. Then I remembered that one of the condition for closed loop is coolant temperature >135F. I compared the coolant temperature reading in my AutoXray scanner against corvettes own display and guess what? According to scanner my coolant never goes above 65F, but corvettes own display is showing normal 187F?! So does this mean that my coolant temperature sensor is bad or my ECM? Anyone any ideas?
Old Jun 16, 2010 | 11:57 AM
383vett's Avatar
383vett
Your coolant sensor for the ecm is bad. It is a different one that supplies the dash readout. I believe the ecm coolant sensor is in the front of the manifold.
Old Jun 16, 2010 | 12:12 PM
jutammel's Avatar
jutammel
Ahh, I think I know what sensor you mean. It is just besides the cold start sensor. Just under the air duct
Old Jun 16, 2010 | 02:07 PM
SunCr's Avatar
SunCr
Check it cold to make sure it's close to ambient. Make sure there's a good connection. Check the reference - 5 volts - yellow with the harness disconnected. Spend 12 Bucks on another one and simply plug it in. If it's now right, R & R the old one. If it's the same and the reference is good, it's the ECM.
To -88 not going into closed loop
