96 LT4...stumble under load until 2k...no codes.
Old Jun 16, 2010 | 05:49 PM
z96lt4's Avatar
z96lt4
Default 96 LT4...stumble under load until 2k...no codes.
I have a stumble under load (1/4 throttle or more) under 2000rpm. It cleans up, almost disappearing around 2k. For example, 3rd gear 1500 1/2 throttle it stumbles until 2000. 3rd gear 2200 1/2 - 3/4 throttle and no stumble. Of course it's more noticeable at lower rpm and lower gear. When it stumbles, it's like it's missing and knocks pretty bad until I back off the throttle. Here's the skinny:
No mods except cat back.
Opti is 3 yrs old but only about 1000 miles on it.
Plugs are 2 yrs old but only about 500 miles on them.
Wires are 1 yr old and only about 100 miles on them.
Checked for loose wires but all were tight. Changed out injectors with known good ones but no joy. Couldn't find any vacuum leaks. This rules out any major causes (fuel, spark). Could it be an O2 sensor? If so, 1st or 2nd? Possible cause is too much advance before the engine can use it, hence the knocking. But what would cause that? I don't get any codes. Bad O2? Does anything happen around 2k rpm like switching fuel maps/spark control? I don't want to spend too much more time/parts chasing it until I can narrow it down a little more. Would plugging a computer into it tell me something I can't see already? Does anyone know a good shop around here who does this?
Thanks for the help.
Old Jun 16, 2010 | 07:25 PM
toptechx6's Avatar
toptechx6
https://virginiaspeed.com/Home_Page.html
Contact forum vendor edcmat-l1
Old Jun 16, 2010 | 07:42 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
I had a miss or hiccup in the higher RPM range and it turned out to be a bad maf..
Old Jun 16, 2010 | 09:13 PM
z96lt4's Avatar
z96lt4
I'll give them a ring. I'll check into the MAF as well. What's the use of having a computer control things if it won't tell you exactly what's wrong?! Thanks for the info.
Old Jun 17, 2010 | 12:51 PM
FireRoc's Avatar
FireRoc
Can you please post what you find out. We have the same issue with our '94 LT1.
Old Jun 17, 2010 | 01:54 PM
jmgtp's Avatar
jmgtp
My 94 had this problem - it was a failing ignition control module.
Old Jun 17, 2010 | 03:04 PM
z96lt4's Avatar
z96lt4
Sure will.
Old Jun 17, 2010 | 04:17 PM
JAKE's Avatar
JAKE
A bad TPS can also cause hiccups like you're experiencing. You can use a digital volt meter to see that the voltage increases smoothly - without sudden skips or jumps - as you open the butterflies.
Jake
My son, Ryan M. Cameron, graduated from West Point on 22 May 2010! He was commissioned as a 2nd Lieutenant and I pinned on his first pair of "Butter Bars" PROUDEST DAY OF MY LIFE!!
Old Jun 18, 2010 | 07:34 AM
Leec4ce's Avatar
Leec4ce
PM me we can clean the MAF or you can use a good MAF to trouble shoot.
To 96 LT4...stumble under load until 2k...no codes.
