How easy to upgrade window regulator?
Old Jun 16, 2010 | 09:00 PM
tjb101084's Avatar
tjb101084
Default How easy to upgrade window regulator?
I have a 87 and am thinking of buying a pair of scissor style window regulators that came off a 90. Is this an easy upgrade? Has any one had personal experience with this?
Old Jun 17, 2010 | 01:39 AM
C4boy's Avatar
C4boy
I thought the 87s came with the scissor style jacks? If not, look on the bottom of your door, underneath. See if it has holes there already (or is it a slot) for the scissor regs. I forget. The hardest part is adjusting the glass to prevent leaks.
Old Jun 17, 2010 | 01:45 AM
jhammons01's Avatar
jhammons01
This is a 2 on a scale of 1-10 with 10 being the hardest.
It takes a whole hour to do. The results are well worth it. and yes you should already have the scissors...but the motor could be old and weak at this stage.
Old Jun 17, 2010 | 10:35 AM
tjb101084's Avatar
tjb101084
I took the door off last week due to the ribbon fell out the motor and my window dropped. I am sure I dont have the scissors. I will buy them thanks for the info
Old Jun 17, 2010 | 04:44 PM
Steve59's Avatar
Steve59
I'm also interested in this thread. I have an 87 and I too thought that they came with the scissor style.
Old Jun 18, 2010 | 02:16 AM
HlhnEast's Avatar
HlhnEast
I agree with J, this is an easy upgrade but can be tedious with adjustments to the window. I had to "roll up" and "roll down the assembly to get it in easier, about half way works good if I remember correctly. Still didnt take very long.
Other members provided me an install guide for the newer design regulator and a window adjustment guide in .pdf format. I will be glad to pass them on to you if you need them. PM your email addy and I will be glad to send em to ya.
Good luck!
Old Jun 18, 2010 | 05:07 AM
Joe C's Avatar
Joe C
here is the retrofit instructions from mid america. hope this helps...
http://content.mamotorworks.com/pdf/604603.pdf
To How easy to upgrade window regulator?
