eckler ram air???
Old Mar 21, 2002 | 03:06 PM
rocky5's Avatar
rocky5
Cruising
Default eckler ram air???
I know cutting the factory lid works , but this eckler front design looks like it has to work better. Has anyone had any positive results after using it?
Thanks :chevy
Old Mar 21, 2002 | 06:17 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: eckler ram air??? (rocky5)
I don't know which one you mean. I have the SLP ram air that effectively has a scoop on the front edge of a closed air filter lid. This scoop extends down into the radiator's air stream. It requires cutting out a section of the front of the radiator shroud. Cost is about $150; if you're clever you could make one.
It added about 5hp or 0.5mph at the traps.
[Modified by 65Z01, 4:18 PM 3/21/2002]
Old Mar 21, 2002 | 09:22 PM
rocky5's Avatar
rocky5
Cruising
Default Re: eckler ram air??? (65Z01)
Sorry I did not clarify. The one I am refering to is the one were you remove
the front liscense plate cover and install there duct work from the nose back.
It seems this should work better than most.
Old Mar 22, 2002 | 06:30 AM
93 ragtop's Avatar
93 ragtop
About a year ago someone posted pictures where they blocked off the air intake through the origional lid, and then cut a hole through the bottom of the filter housing and shroud and put a cone type filter in it. I never heard anyone else coment on doing this but it looked like a good way to get the cold air intake cheap!! I printed it and I believe I have it in a book somewhere.
To eckler ram air???
