Rear wheels/Spring
Old Jun 19, 2010 | 01:10 PM
HlhnEast's Avatar
HlhnEast
Default Rear wheels/Spring
When I jack up the rear of the car, the rear wheels droop/roll under to where the back end of the car is 2' or better in the air before the tires even think of coming off the ground. Is this normal or is something in the suspension like the monospring worn out?
Old Jun 19, 2010 | 01:15 PM
94z07fx3's Avatar
94z07fx3
That sounds normal. When the car is on the ground weight on the wheels does it look to have negative camber? Is the camber symetrical? Does it look like normal ride height?
You can always sponge off the spring and look/feel for cracks.
Old Jun 19, 2010 | 02:07 PM
383vett's Avatar
383vett
Normal. The strut rods are not parallel to the halfshafts so as the rear suspension goes through it's travel, the camber changes from negative when the rear is loaded to positive when the rear is unloaded.
Old Jun 19, 2010 | 07:46 PM
HlhnEast's Avatar
HlhnEast
Thanks guys, I was just curious. When it sits on the ground everything is fine. Its just hard to get the tire off the ground and made me wonder about it.
Old Jun 19, 2010 | 09:40 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Ditto and I think it looks kinda cool
Old Jun 19, 2010 | 09:57 PM
samsonb's Avatar
samsonb
How are you jacking it up? I jack my rear tires one at a time via the stock jacking location. Doesn't take too long to get the tire off the ground.
Old Jun 20, 2010 | 01:51 PM
HlhnEast's Avatar
HlhnEast
I use the standard jack location. Just seems like its way high before the wheel clears the ground. I would hafta take the tire off before I set it on the jack stands I would think unless I want the car way off the ground.
To Rear wheels/Spring
