Raptor shift light install on 96 LT4
Has anyone installed a Raptor shift light in a 96, if so, any suggestions as to what wires to look for for connections, (easiest acces wires that is , partially dissabled).
Any help would be greatly appreciated, even better if someone made photos of there install to show the process.
Thanks folks
Thanks folks
http://www.hashmarks.com/ShiftLight/page1.html
You need to splice into the tacho signal wire ( white ) from PCM to dash somewhere .Don't have a '96 FSM to help you there
As well as a hot ; key on supply
Thanks.
And as far as installing in the a/c vent, IMHO I think would be a pita if you have to change shift point setting, although it is a pretty slick area, but I really am not going to remove a/c vent blades either.
But thanks for the pics
Finding and connecting the tach lead wire (white) at the C-100 is the most difficult part.
