c4 modification
Old Jun 22, 2010 | 01:46 AM
1986 4+3 CORVETTE's Avatar
1986 4+3 CORVETTE
Default c4 modification
I just got an off road h pipe for my car and am wondering what other mods to do with a 500$ budget im thinkin a throttle body or injectors tell me what you think thanks, by the way i have an 86 TPI
Old Jun 22, 2010 | 02:06 AM
Mikes1991's Avatar
Mikes1991
Well if you have the original Injectors Id definitely check them out to see if the meet specs OHMs etc Fic sells em pretty damn cheap. If the car is running well, Idles well, you can probably skip injectors. I only mention this because you mentioned Injectors
Id do a set of under pullies and a chip from hypertech or superships and a ported throttle body. That should make you feel nice for now and leave a few bucks in your pocket. Id buy everything on ebay for way less and id get it used. The pullies you probably wont find used but who knows perhaps you will. Hope that helps
Old Jun 22, 2010 | 02:24 AM
rodj's Avatar
rodj
Originally Posted by Mikes1991
a chip from hypertech or superships .
All right if you want to turn fans on sooner
Most here wouldn't waste the $$ on a Hyper cr*p chip
http://forums.corvetteforum.com/c4-t...-are-exhs.html
http://forums.corvetteforum.com/c4-t...post1564778076
http://forums.corvetteforum.com/c4-t...tech-chip.html
http://forums.corvetteforum.com/c4-t...-any-good.html
And a bigger TB is a waste on a otherwise stock engine
See here for mods what works and don't
http://temp.corvetteforum.net/c4/vader86/minormods.html
http://temp.corvetteforum.net/c4/vad...dstrategy.html
Best bang for $$$ on L98 is long tube headers and decent exh system
Cheapo painted ones $170
http://www.summitracing.com/parts/HED-68440/
Old Jun 22, 2010 | 03:27 AM
1986 4+3 CORVETTE
do you know anyone that has used those hedman hedders and would it work well with an H pipe
Old Jun 22, 2010 | 03:40 AM
darkstallion_69's Avatar
darkstallion_69
wow headers for pre 91 are cheap! i wish they were that cheap for the lt1
Old Jun 22, 2010 | 03:44 AM
rodj's Avatar
rodj
Did you read the modification links I put up above ?
"So the best bet is to install longtube headers, Most will show the same 10-15rwhp gain",
Long tubes are long tubes;
I doubt you will see any difference on a stock engine compared with the $600 ones
http://www.jegs.com/i/Hooker/520/2149/10002/-1
Old Jun 22, 2010 | 08:16 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
No throttle body, no chip, headers are a good idea. The coated Hedman Elites are only $360. Get the coated ones. They will work with a H pipe but you may have to adjust the length. Check out Summit. Don't replace injectors until they go bad.
Old Jun 22, 2010 | 08:22 AM
drjimmy's Avatar
drjimmy
I have ran mine for nearly 10 years. Not dissapointed.
Old Jun 22, 2010 | 09:17 AM
vader86's Avatar
vader86
Headers, 1.6RR, or perhaps a new set of runners or a base manifold with that budget.
Old Jun 22, 2010 | 10:12 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Take a look at Vader's web site as he has a good analysis of what results you can expect to achieve from various low cost L98 modifications. FWIW
Old Jun 22, 2010 | 11:00 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
I have uncoated Hedmans. If you live in a dry climate I think you'll be fine with them. Do you have cast iron or aluminum heads?
Old Jun 22, 2010 | 11:22 AM
mcm95403's Avatar
mcm95403
Better mufflers? Flowmaster has a cat-back system for your car that is just under $500. http://www.summitracing.com/parts/FLO-17153/
I'm curious though - what brand h-pipe did you get, and is it mandrel bent?
Old Jun 22, 2010 | 12:59 PM
BADDUCK's Avatar
BADDUCK
Trust me Pullayup Washington is not a dry place.
Old Jun 22, 2010 | 04:04 PM
clok1966's Avatar
clok1966
Exhuast seems to be the easiest and cheapest upgrade. Anybody used any of the duel exhuast setups? I have a friend with a Muffler shop but he always said he couldnt remove CATS even if I live in a state with no Emisions checks (North Dakota). Google searches make it look like the only lwas i have to worry about is "no bypass or cutout" so a standard mufflered duel exhuast should be fine. or am I missing some part? As long as I put in a bung for the O2 sensor shouldnt I be fine?
I was looking at some Headers, duels and 2 mufflers at the back in the standard spot.
Old Jun 22, 2010 | 04:46 PM
1986 4+3 CORVETTE
how much hp at the fly wheel do you think id get from an h pipe and long tube hedman thermal coated heddars
Old Jun 22, 2010 | 07:07 PM
BADDUCK's Avatar
BADDUCK
IMO H pipe not much. Hedman Elites at least 15 maybe 20 CHP.
Old Jun 22, 2010 | 07:31 PM
John A. Marker's Avatar
John A. Marker
with rodj on list of modifications and Vader86. If you read Vader's web site you will come up with a better understanding of what works and what does not.
Exhaust
1.6 RR
Better intake/runners/plenum
forget TB - the stock can handle up to about 400 HP and you are far from that.
Forget Hypertech chip
I don't think the "H" pipe will give you much, especially if you have installed the "test pipe". You should see a good gain with just this.
Cut out air cleaner box louvers.
To c4 modification
Old Jun 23, 2010 | 02:00 AM
1986 4+3 CORVETTE
whenever my car gets to around 4000rpm it gets real shakey but everything else is fine and it drives great does anyone know why this happens
Old Jun 23, 2010 | 02:06 AM
1986 4+3 CORVETTE
does anyone know how much roller rockers cost to install
Old Jun 23, 2010 | 10:15 AM
mcm95403's Avatar
mcm95403
What do you mean by "gets realy shakey"?
You can install roller rockers yourself, it's pretty low on the difficulty scale. If you have a shop do it, it should be 1 hour or less for a shop mechanic to do.
