harmonic damper
Old Mar 21, 2002 | 08:46 PM
dave g's Avatar
dave g
Default harmonic damper
does any body know if a 8 inch harmonic damper well clear the cross beem on a 86 vette . im going to order a 383 and the guy wants to no if i have room for a 8 inch harmonic damper. any help would be great and also injectors when i get bigger ones do you have to get a different chip burned.
thanks
dave
Old Mar 21, 2002 | 09:27 PM
No Go's Avatar
No Go
Default Re: harmonic damper (dave g)
I don't believe it will. There has been discussions on this topic-may try a search.
You can run the injectors with current program, but it will be richer than original...whether you want or need that...???
Good Luck:)
Old Mar 21, 2002 | 09:33 PM
MCPOWHITE96's Avatar
MCPOWHITE96
why the big one? wouldnt a stock or aftermarket fluiddamper work?
To harmonic damper
